I have a new 27inch iMac - December 2012.
I’m running Audacity and my USB interface is a Focusrite Scarlett 2i2. I have KRK Rokit 5 speakers and my microphone is a Neumann TLM 103 which plugs into the inputs of the Focusrite with an XLR cable to record.
I only use this setup to record voiceovers.
Ok, here’s the problem…
When I put plug the mic into input 1 of the Focusrite and record with Audacity set to 1 (Mono) Input Channel, it records fine and I can hear the recording from both left and right speakers. When I use the same input - number 1 on the Focusrite - and set Audacity to record in 2 (Stereo) Input Channels I only hear the recording from the LEFT side speaker.
If I then change the input of the mic to input number 2 on the Focusrite and record, I only hear the recording from the RIGHT side speaker. Then if I stay in input 2 on the Focusrite and change Audacity back to the 1 (Mono) Input Setting to record, I get a signal going into the Focusrite but then when I hit record there is no wave showing on Audacity, just a flat line.
I took the Focusrite back to the store today and the guy tested it and it seems to be working fine. Is there something I’m doing wrong that I need to change on the iMac or is there something in Audacity that needs to be changed to at least let me record in MONO on input number 2 on the Focusrite? I’ve tried evrything I know!!
Thanks for reading this and any help appreciated.
