I’m totally new to using Audacity and could use a little help. I have version 2.1.3 on Windows 10 using a Behringer UCA222 audio interface. I’m getting a stereo signal but seem to have very little control over the input signal. Best I can get for input is around -15db. If I push the input level to full up it goes into clipping. Do I need a pre-amp off my turntable?
Describe the turntable. Normally, neither the turntable nor the 222 have volume controls.
Thorens TD 125 turntable, Rabco linear tracking tone arm w/ Grado stylus and cartridge. No gain controls on the turntable or interface.
[Puzzled puppy look]
Where are you pushing?
The input level on the Audacity control page. Upper left corner with the “mic” icon. It’s set at just under “+”; if I go full up I get clipping bad.
