Need Help :)
Wondering if you got any ideas on creating a drum and bass enhanced version of a song on audacity…ive tried use bass boost its good but wondering if there are any other effects available.
You want to change the drums on a song that’s already a finished musical performance? That’s rough because anything you do is going to affect the whole performance, not just the drums and bass. If you have a separate drum track, then there’s a number of odd things you can do.
