Need help with audio file on 2.3.1
Hi,
I am trying to clean up an audio file that was sent to me and am having difficulty making the voices clear. I am able to eliminate most of the background noise but am still unable to make out the voices fully. Will someone be able to take a look at a sample of the audio file for me and help me clear it up a little?
Thank you
You need to be able to hear voices clearly at the beginning for the Audacity tools to be effective. We can’t pull a voice out of the mud.
That and we can’t do surveillance, law enforcement or conflict resolution.
Thanks for replying. I’ve included a clip of the file - it’s a sample I got but the voices don’t seem that bad. Just seems to have an echo/slight distortion that I can’t seem to remove.
There’s no echo on that recording.
It may be your computer’s sound-card (not Audacity) is adding a roomy surround-sound effect,
(see speakers properties enhancements).
If you generate a bleep and that also has an echo/reverb, then the computer (not Audacity) is adding the effect,
see … Audacity as reverb detector
