Hello,
I need help in discovering how a sound effect was made, please excuse if i use any incorrect lingo! i am using version 2.1.0
Basically i am using a program called voice attack in junction with the PC game Elite dangerous, i have been using a voice pack called A.S.T.R.A, i say a command like “lower landing gear” the computer voice replys “yes commander” or some thing similar…
here is a demonstration:
https://www.youtube.com/watch?v=s4QkltClArw
The pack i got only has limited phrases and i want to broaden them and make them myself. I have downloaded a program where i can “type to speak” and the outcome is a .wav file, but they do not sound very computerised like in the video i attached above.
I have downloaded audacity to see if i can change these new voice commands so they sound exactly like they do in the you tube clip, but i know very little about such things, here is where i need your help! Notice how the voice is computerised, kind of “tinny” it sounds like the computer of the enterprise! does anyone have any idea what setting/effects i should use?
Any help would be amazing!
thanks guys!
