need help quickly
do to an error on recording all i have is 400 plus au files. is there any way to get them together without pastein them one at a time?
Thanks
Jim
There is no good way to reconstruct a show from interrupted capture clips.
<<<without pastein them one at a time?>>>
You may not be able to do that, either. Audacity doesn’t always save the capture clips or number them in order.
Once you kill a live recording, it’s dead.
