Running Yosemite, 10.10.1 with Audacity 2.0.5
Want to link up my mic and I have a Logitech h390…
Thanks for the help, guys!
-J
-J
Got it.
So you are all fixed up? USB devices should be connected before launching Audacity, otherwise use Transport > Rescan Audio Devices in the Audacity menu bar.
You may also need to set up the mic in Applications/Utilities/Audio MIDI Setup so that the mic is selected and so that its sample rate is the same as Audacity project rate (bottom left of the Audacity window).
Note that Audacity does not yet officially support Yosemite.
