Need help deleting Accu/aufx/Aca /accusonus: ERA 5 Audio Clean-Up Assistant
Hey guys, whenever I open up Audacity 3.7.3, I get a pop up window which reads, Accu/aufx/Aca /accusonus: ERA 5 Audio Clean-Up Assistant". I know what this plugin is and I’ve disabled it the the Plugin Manager but I’m still not able to get rid of the pop up. I already have ERA 6 so deleting this is not an issue. Where do I find the Accu/aufx/ACA file on my Mac? Thanks!
In Audacity, go to Effect (menu) > Plugin Manager. The list in the Plugin Manager window should show you the path to the plugin.
I appreciate the info but that didn’t seem to solve the problem. What did work though was going to Preferences, Effects and check marked “Skip effects scanning at startup.”
