Need help changing the sound of the voice because it sounds weird
I really need help with my song, i decreased speed and the voice sounds weird. any way to fix? i have an .mp3 file btw
I’m using an older version of Audacity, version 2.3.1, so I don’t know if they’ve changed it on newer versions or not, but my Effects menu also has “Change Tempo.” If I start to use “Change Speed,” the dialog box says it changes both tempo and pitch. If I select “Change Tempo,” the box says it changes the tempo without changing the pitch. So maybe you should try using “Change Tempo” instead of “Change Speed” and see if that works for you.
