Need Help! .Aup currupt but data intact.
I need help getting a corrupt .Aup file to find it’s data samples.
Audacity 1.3 Beta was used to record, as the computer used was windows xp and had no internet connection for some time.
I had the saved file open and playing, when my pc crashed, and the hard drive went into RAW format.
so automatic recovery was not an option.
I left everything untouched, and hooked it up as a slave drive, with a new master hard drive installed, I then used Yodot hard drive recovery to get my files back.
I had a audacity 2.0 on a usb, so I installed it on the new hard drive and loaded up my files, all files are intact, and copied exactly as they sat in the old hard drive, nothing re-named, nothing moved, and everything worked as far as retrieval, except 1 song.
It attempts to load, but has deformed wave lines and spots of silence through out, and if you try to play it, it will crash.
if you export it as a wav. it will not be music anymore… lets say it that way lol
I loaded up some of the samples out of the data folder, and they “SEEM” intact.
so I would imagine the samples are all ok, but the .Aup can’t load them correctly.
big issue is the tracks have been panned out in stereo for the hook, and background effects.
so piecing the mono samples together is not an option.
below is the report I receive when loading up my .Aup file.
19:02:51: Audacity 2.0.0
19:02:52: Error: Couldn’t find symbol ‘MainPanelFunc’ in a dynamic library (error 127: the specified procedure could not be found.)
19:02:53: Trying to load FFmpeg libraries…
19:02:53: Trying to load FFmpeg libraries from system paths. File name is ‘avformat-52.dll’.
19:02:53: Looking up PATH environment variable…
19:02:53: PATH = 'C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;c:\Python22;C:\Program Files\Sonic\MyDVD;;C:\Program Files\MUSICMATCH\MUSICMATCH Jukebox;C:\Program Files\Common Files\Roxio Shared\9.0\DLLShared'
19:02:53: Checking that ‘’ is in PATH…
19:02:53: FFmpeg directory is in PATH.
19:02:53: Checking for monolithic avformat from ‘avformat-52.dll’.
19:02:53: Error: Failed to load shared library ‘avformat-52.dll’ (error 126: the specified module could not be found.)
19:02:53: Loading avutil from ‘avutil-50.dll’.
19:02:53: Error: Failed to load shared library ‘avutil-50.dll’ (error 126: the specified module could not be found.)
19:02:53: Loading avcodec from ‘avcodec-52.dll’.
19:02:53: Error: Failed to load shared library ‘avcodec-52.dll’ (error 126: the specified module could not be found.)
19:02:53: Loading avformat from ‘avformat-52.dll’.
19:02:53: Error: Failed to load FFmpeg libraries.
19:02:53: Error: Failed to find compatible FFmpeg libraries.
19:03:42: Warning: Orphan block file: ‘C:\Documents and Settings\Chris\My Documents\Back up\Documents and Settings\Owner\My Documents\My Music\Sampsonite\Wasted Years\Files\Free Rap Instrumental - The Hard Way (New School Beat)_data\e00\d00\e000021e.au’
19:03:42: Warning: Orphan block file: ‘C:\Documents and Settings\Chris\My Documents\Back up\Documents and Settings\Owner\My Documents\My Music\Sampsonite\Wasted Years\Files\Free Rap Instrumental - The Hard Way (New School Beat)_data\e00\d00\e000090d.au’
19:03:42: Warning: Orphan block file: ‘C:\Documents and Settings\Chris\My Documents\Back up\Documents and Settings\Owner\My Documents\My Music\Sampsonite\Wasted Years\Files\Free Rap Instrumental - The Hard Way (New School Beat)_data\e00\d00\e0000b48.au’
19:03:42: Warning: Orphan block file: ‘C:\Documents and Settings\Chris\My Documents\Back up\Documents and Settings\Owner\My Documents\My Music\Sampsonite\Wasted Years\Files\Free Rap Instrumental - The Hard Way (New School Beat)_data\e00\d00\e0000e59.au’
If anyone can help me, I’d greatly appreciate it!
Thanks all
I think that’s the end of the world.
There’s no good way to put an edited stereo show back together without the AUP file.
If someone had a gun, the desperation method is open the little six-second AU files one at a time and see if you can figure out where they go in your song, and whether they’re left or right (they alternate) but I’d say you can’t do even that any more because of missing or corrupted AU files.
So this is where you start thinking about remaking the work from the original music files.
There’s a new-user mistake where they correct, patch and edit original sound files. In the case of disaster, they may need to download the sound files again. There is no backup.
