Audio software recommendations to meet the requirements below:
I have loads of parts within an audio file that need deleting and there are too many to do after the recording, the parts that I want to delete must be marked whilst I’m playing the file back. As the slider moves across the audio stream during playback I want to be able to select multiple start and end points (which should be stored in a cut slection list) to be excluded when I save a new copy of that audio stream.
I have an example of how this is done with my video editing software in the link below, but I need one for audio. As you can see there is a button to select the start time and another for the end time, then I press another button to add this to the cut list and from there I am free to add other start and stop times to the cut list. Once I’ve finished each start and stop time it pauses briefly, but the index marking is being done when the stream is being played and the editing is done after playback is stopped or finished.
http://i108.photobucket.com/albums/n20/contactadam2002/dddddd.jpg
