my vinyl recordings sound bad
Hi all!
I am playing vinyl records on a Technics SL1210 MK2 / ortofon 2M cartridge / Art pre II preamp going into Focusrite Saffire LE line in. When playing the records, they sound fine.
However, when recording them with Audacity 2.0.2 (mac OS X 10.8), with levels correctly adjusted in preamp / audio interface / audacity, and audacity quality preferences :
44100 / 32 bit float / high quality everywhere, the result is baaaad. Not horrible, but definitely worse : slightly distorted, lack of bass, backgroung noise volume higher
than original… I have tried different settings in audacity “preferences”, but it sounds about the same shit…
Any idea what could be the problem ?
thanks!!
Audacity 2.0.2 is legacy now so you should upgrade at http://audacityteam.org/download/mac , though it won’t be relevant to your problem.
If your Mac only has a combined audio input and output, that is not suitable. Buy a USB interface with a line-in input like one of these: http://wiki.audacityteam.org/wiki/Recommended_sound_devices#USB_Interfaces .
Also navigate Apple Menu > System Preferences > Sound. Choose the “Input” tab and ensure that any “Use ambient noise reduction” control is unchecked (not ticked). You may have to select the built-in internal microphone to make this checkbox visible.
Attach a short WAV sample of the problem if you are still concerned. Please see https://forum.audacityteam.org/t/how-to-post-an-audio-sample/29851/1 for how to provide this.
