music sample has lots of pops and scratches
Hello,
I’ve attached a 15 second mp3 file that has alot of pops and scratch noise. I’ve tried many suggestions to remove/reduce them (while not harming the music) w/out success.
This is just a short sample of an hour long tape w/ the same pops and scratches throughout.
Hopefully someone can recommend a better way.
Thanks Thanks
In some cases there is no music when the pop/scratch occurs
So best-case-scenario there will be silence where the scratch was.
Have you tried editing the original recording, or was it converted to mp3 first? (e.g. .WAV file) This can make a difference.
Thanks, that works, but there are hundreds if not more :frowning:
Thanks, yes I do have the wav file and I’ve tried all the suggestions on it, but the same poor results. :frowning:
So I tried two things on this mp3 file:
The first thing I tried was using audacity’s built-in click-removal. I first Normalized the audio, then ran click-removal with the parameters 110, 40.
The second thing I tried was using Paul’s De-clicker nyquist program with the built-in parameters. See: Updated De-Clicker and new De-esser for speech
However, be warned: This plug-in doesn’t like long files.
I had similar results each way. You can also try combining the effects or working with the parameters. Good Luck. :smiley:
Are you sure those aren’t digital capture errors? Can you listen to the actual player with headphones?
ya. I listened w/ headphones. :frowning: the cassette tape is very old.
