I have a number of cassette tapes, each with a relatively short recording time. I would like to record each tape with its own label, but in the same “file”. In the same way as I have multiple tracks on an CD album. In order to jump to a specific recording (e.g. song # 4 on a CD.
Is it possible to create this file? If so, how? I am using Audacity 2.1.0.
Please advice!
See: https://manual.audacityteam.org/man/splitting_a_recording_into_separate_tracks.html
each will be a separate audio file - but you can keep them in their own folder.
Audacity 2.1.0 is way out of date. The latest Audacity version is 2.2.1 and you can get it here.
http://www.audacityteam.org/download/windows/
Thank you for the advice! And quick respons!
I will read in the manual and try this out. The text says “… burn to a CD” but I’ll guess to export to e.g. an MP3 file will also work?
BR/SivrosJ
