Multiple Issues / Crashes
Hey all,
I was hoping I could get some help here.
I’ve been trying to get started using Audacity for several days now and I keep running into different issues that seem to be changing in severity minute by minute.
I’m running Ubuntu 22.04.1LTS and Audacity is 3.1.3 and appears to be up to date with what’s in the app store on Ubuntu.
Currently when I open Audacity I have ALSA available and selected as audio host. However no options appear in the recording device or recording channels drop downs. I have previously been able to select ‘Default’ in the recording device tab but no longer can.
Previously when I was able to select ‘Default’ in recording device Audacity would not show up in Pulse Audio. I’m trying to record streaming audio. A couple nights ago this all seemed to be working after a long evening of Googling and experimenting but now after my computer has been powered down for a day the issue seems to have regressed somehow.
Here’s what comes up when I diagnose audio device info:
Default recording device number: -1
Default playback device number: 0
Device ID: 0
Device name: HDA Intel PCH: HDMI 0 (hw:0,3)
Host name: ALSA
Recording channels: 0
Playback channels: 8
Low Recording Latency: -1
Low Playback Latency: 0.00580499
High Recording Latency: -1
High Playback Latency: 0.0348299
Supported Rates:
    32000
    44100
    48000
    88200
    96000
    176400
    192000
Device ID: 1
Device name: HDA Intel PCH: HDMI 1 (hw:0,7)
Host name: ALSA
Supported Rates:
    32000
    44100
    48000
    88200
    96000
    176400
    192000
Device ID: 2
Device name: HDA Intel PCH: HDMI 2 (hw:0,8)
Host name: ALSA
Supported Rates:
    32000
    44100
    48000
    88200
    96000
    176400
    192000
Device ID: 3
Device name: hdmi
Host name: ALSA
Supported Rates:
    32000
    44100
    48000
    88200
    96000
    176400
    192000
No recording device found for 'default'.
Selected playback device: 0 - HDA Intel PCH: HDMI 0 (hw:0,3)
Cannot check mutual sample rates without both devices.
And here is what shows up when I diagnose MIDI device info:
Default recording device number: 1
Device ID: 0
Device name: Midi Through Port-0
Host name: ALSA
Supports output: 1
Supports input: 0
Opened: 0
Device ID: 1
Host name: ALSA
Supports output: 0
Supports input: 1
Opened: 0
Selected MIDI recording device: 1 -
Selected MIDI playback device: 0 -
I appreciate any help you guys could give me.
Just found that there is a newer version of Audacity and the distro version is out of date. Gonna try and get the new one going and see if that helps.
Issues resolved by downloading the AppImage file from Audacity.
