Hi,
I’m using audacity 1.3.12 on a Debian/Squeeze box.
I have big audio files which consist of words/phrases : it’s a language course (FSI).
I used the sound finder to detect and mark all the separate words/phrases.
I checked them all and modified what was needed. This was ok and fast.
Now, I have 1000 marked regions in every file.
I use export multiple to create individual files: the problems began here:
- I have to “validate” for every marked place
:(: a button for export all would be fine …
- I create a specific “tag model file” with personal tags (the shtooka project tags) because I wanted theses tags in my files: I have to load this file for every export file (so 1000 times in my case … ): why did’nt audacity keep the tag model file I chose at the begining? It’s a model.
- Audacity also delete the tags which are empty
- If I add a tag in the file, delete one, the tags are renamed when reloaded: why? It’s a pain to keep synchro between the files names and their content which I wrote in the marker’s export file.
Maybe there is a way to do it, but I didn’t find it.
Best regards,
