when using (export multiple) in audacity,is there any way to permenantly untick the (overwrite existing file) box as i keep forgetting to unclick it.it would also save time as i use quite a lot–mickthefish.
I’ll move this to the “adding features” part of the forum.
I agree that it would be better if the user setting was retained, (and for safety, the default set to unchecked, don’t overwrite).
It’s a very simple change; currently (before the change to wxWidgets 3) the code looks like (in \src\export\ExportMultiple.cpp at or near line number 352):
Hi Gale-I suppose it depends on what project your working on wether you prefer the checkbox (ticked or un-ticked)if as you say most people prefer it set to overwrite.not an easy FIX for me though!-mickthefish.
I tried that first and got a compiler warning (maybe because “true” can be defined as a BOOL or as an INT depending on the OS and/or compiler). If you search the code for other instances where we use a TieCheckBox you will see that, historically, it is done the way I did it. FYI your way does not work on my system (Windows 7, MSVS 2010 & 2013, WxWidgets 2.8 - next week I should be on Windows 10, MSVS 2015 & wxWidgets 3.0).
