multiple effect
hello
why do i have effect in double .
one with … working
one with… not working .
thanks for your help
mac book pro os 10.8.5 Adcty version 2.1.1 dmg installer .
Gale did post an answer to your question, see … https://forum.audacityteam.org/t/effect-in-double-attachement/39746/2
When upgrading to a new Audacity version, it is probably easiest to trash the folder containing the previous Audacity version, then give the same name to the new folder. That way, you will not create duplicate plugins.
If you have any plugins in the Audacity “Plug-ins” folder that did not come with Audacity, copy those plugins to your Desktop before deleting the old Audacity version. Then paste the old plugins into the “Plug-ins” folder in the new installation.
