Multi-Selection ?
OK so I tweaked these two pages in the 3.2.0 alpha manual:
a) https://alphamanual.audacityteam.org/man/Tracks_Menu:_Mix#mix_and_render
b) https://alphamanual.audacityteam.org/man/Mixing
I decided not to bother with the edge case of “selection” being triggered by just cursor position(s) being present in tracks.
“My work here is done.”
Peter.
:smiley:
@Steve
Your latest macro works with mono and stereo files and combination of the two.
(Audacity Ver 2.4.2).
Thank you.
@Peter
Thanks for your method as well, like I said, depending on situation, will put it to use as well.
Thanks waxcylinder. I’ve tweaked it a little more as I though the use of the word “selected” in the “Advice” box might be misinterpreted to mean that the temporal selection would be changed.
Yepper, I saw that - a good improvement IMHO - thanks :slight_smile:
Peter.
