Group
Where do I find instructions on Saving an Audio File as an Mp3, Then burning the Mp3 to a DVD?
Bill
Group
Bill
You have to install the Lame software for Audacity to make an MP3 sound file.
http://manual.audacityteam.org/o/man/faq_installation_and_plug_ins.html#lame
Then File > Export and select MP3 and set the encoding options. Audacity default options are usually OK.
Audacity doesn’t burn anything. You have to go to outside software for that. Windows Media can be used to burn a CD, but burning a DVD is up to you.
Hello
Whackett here. I will give the procedure a try.
Thank you,
Bill
