Mp3 file wave form cut in half and above center
Greetings Audacity Forum!
Please excuse my lack of experience. I have no idea how or why this file is the way it is, but can it be repaired?
I tried the normalize, like I have done on so many other recordings, but I have never seen anything like this.
How bad does it sound? You probably can’t fix the sound. :frowning:
Normalize with Remove DC Offset will make it look better but it won’t do anything for the sound.
Or try a high-pass filter at 20 or 30Hz, and then normalize (or amplify) to bring-up the volume. (Again, don’t expect any improvement in sound.)
…There’s a general rule that “you can’t fix distortion”. :frowning:
wow, thank you, that did it… High Pass filter, normalize then loudness.
