Hi. I am using Audacity 2.0.3 (installed from .exe) on Windows 7. I have an MP3 file that I have made labels in, and when I export multiple, based on labels to 128k constant bitrate stereo MP3 files, there is a small audio “pop” or glitch at the beginning (about 1-2 seconds in) of SOME (most) of the exported files. This pop is not in the source file, and does not occur when I export to wav. Any thoughts???
Thanks for the response. I did that and I am still getting the pop. I’ve attached a bit of the export. You can hear the dropout (or whatever it is) after he says “Here’s the.” It only happens in MP3 exports, and only happens at the beginning of the file.
