Move selection without changing the length
windows 7
2.0.5
exe
is it possible to shift a selection, keeping the length the same?
i want to use it to find good loops from a song
Theory has it you can use the time entry windows at the bottom of the window. Select Start for the first one and Length for the second.
Would you like to request a way to do that by dragging the selection with the mouse?
