The title says it all. I’m just trying to splice some audio. It isn’t going well. I feel I need to move the playhead to the end. I don’t want to use the cursor because it’s never EXACTLY at the end. Is there a button to move the playhead to the end?
Fn key with the right-arrow key should smash the cursor all the way to the end. That’s the equivalent of the Windows END key.
Thanks! BTW - does the k key do the same?
So that would be yes.
