I remember reading that some folks were having trouble with Audacity and the Beta of MacOs Mojave 10.14.4. I see that Apple has released that version now and wanted to hear if anyone has installed it and if Audacity 2.3.1 is working okay? I like to wait a bit after a new release to see the fallout.
Thank-You!
-Ron
Audacity 2.3.1 is a fully qualified 64-bit application and shouldn’t have any more trouble than any other normal Mac app.
There has been some serious trouble between iTunes, AAC/M4A, Audacity and FFMpeg.
You broke the format! No, you! Not my problem!!
“789:57:13” is iTunes-speak for Something Is Wrong.
What Kind of troubles? Do you have a link?
-Ron
https://forum.audacityteam.org/t/acc-file-time-is-changing-to-78913/52423/1
That seems to be iTunes changing a file to 789 hours, but it’s actually an iTunes failure code.
I just installed 10.14.4 and AFAICT Audacity 2.3.1 (64-bit) runs just fine - even the older 32-bit versions of Audacity seem to run OK on 10.14.4
That’s good to know. I still have older, valuable 32-bit apps.
And for now SimpleSynth the app that we recommend for getting MIDI playback in Audacity on Mac still works OK - but it is a 32-bit app.
Peter.
Thank you for all of the replies. I seldom work with AAC/M4A. I use Mp3 and Wav. A carry-over from my Windows days.
Best Regards,
-Ron
