mod-script-pipe loads but no named pipe created on Windows 10 — Claude MCP integration
Hi everyone,
I’m trying to connect Claude Desktop to Audacity using the an3-audacity-mcp MCP server on Windows 10 and have hit a specific issue I can’t resolve. Hoping someone here has seen this before.
My setup:
— Windows 10 Pro (Version 10.0.26200)
— Audacity 3.7.7
— Python 3.14.5
— Claude Desktop (MSIX install, freshly installed as administrator)
What I’ve done correctly:
— Downloaded and extracted an3-audacity-mcp from GitHub
— Created a Python virtual environment and successfully installed all dependencies (mcp[cli]>=1.6.0 and httpx>=0.28.1) with no errors
— mod-script-pipe is set to Enabled in Edit → Preferences → Modules
— Confirmed mod-script-pipe.dll exists at C:\Program Files\Audacity\modules\mod-script-pipe.dll
— Confirmed via PowerShell (Get-Process) that mod-script-pipe.dll IS being loaded by Audacity
— Claude Desktop is installed and the claude_desktop_config.json is correctly configured with the right paths
— Tried toggling mod-script-pipe from Enabled → Disabled → Enabled and restarting Audacity each time
— Tried running Audacity as administrator
— Done a full system restart
The problem:
Despite mod-script-pipe.dll loading successfully into the Audacity process, no named pipe is being created. Specifically:
— Get-ChildItem \\.\pipe\ shows no audacity-related pipes
— Searching C:\Users\…\AppData\Local\Temp\ finds no audacity_script_pipe files
— Searching the entire C:\ drive finds no audacity_script files
Because no pipe is created, the MCP bridge has nothing to connect to, and Claude Desktop shows no hammer/tools icon.
My question:
Has anyone seen mod-script-pipe load but silently fail to create a named pipe on Windows 10? Is there a known fix or a way to diagnose why the pipe isn’t being created?
Any help would be greatly appreciated. Happy to provide more diagnostic info if needed.
Thanks!
That’s a 3rd party tool. I’ve no idea if it works.
Microsoft provide a tool that lists named pipes: Pipelist - Sysinternals | Microsoft Learn
This tool is likely to be more reliable on Windows than simple scripting tests. I’d suggest using this tool before concluding that the named pipes don’t exist.
Let us know what the result is. If there’s still a problem, let us know exactly which version of Audacity you are using.
