mix stereo
Helo everybody,
Audacity 2.0.3
I work on windows 10 and I cannot activate “mix stereo” to register what I jear from the loud speakers (or headphones).
I tried everything I found on forum and notices but nothing is effective.
Please, have you a trick to manage?
Thanks for your answers.
Gilprieur from France :angry:
Some drivers don’t support “Stereo Mix” or “What-U-Hear”.
Try [u]WASAPI (loopback)[/u]. That usually works with Win7 or later.
With (loopback) you may need to start the audio before hitting Record, and the recording may stop if the sound stops/pauses.
Hi,
Thanks for your reply.
That was a good idea, though I did’nt find asapi but “direct sound recording”. Un fortunately it does’nt work.
where do you find “loopback”?
