when you use this feature, Lets say I have 9 traks and add just to my likings. Mix and render to new track, does it change my settings.
Probably not. What “settings”?
volume settings of different tracks
what does render do
See http://manual.audacityteam.org/o/man/tracks_menu.html#mix. Yes it will apply for example the gain or pan setting on the track to the waveform, and so the gain or pan slider will return to centre.
Thank you Gale.
