I built audacity 3.0.0 from source (as I have done for previous version) and I’m hitting the bug
Internal error at DBConnection.cpp line 275.
which is biting other people, as I saw in this forum. As I am using sqlite 3.34.1 and audacity developers test with 3.32.3, I assume the problem lies with my sqlite versinon/compile options. Now, as other packages are fine with sqlite 3.34.1, I’m reluctant to downgrade my local sqlite installation, but instead force the audacity build to use the bundled copy in lib-src/sqlite. However, I cannot find a documented cmake option to specify one?
How can I force the audacity build to use the internal copy of sqlite instead of the system one?
On Debian based distributions you can remove the “-dev” packages for the system versions. The -dev packages contain the software headers and are only required when building. If the system -dev packages are not available, then Audacity will build with the local version.
There’s not currently much debug information relating to the database.
To access the Audacity log:
“Help menu > Diagnostics > Show Log”
More debug information is available when launching a Debug build from a Terminal, but still not much re. the database.
To create a Debug build, use:
cmake -DCMAKE_BUILD_TYPE=Debug ..
Audacity 3.0.1 will contain more debug information relating to the database (this is being added now to aid investigation of this type of problem).
The latest development source is available from GitHub: https://github.com/audacity/audacity
I’ve found some information re. “Unable to parse project information”
I’m reading through it now and will get back to you.
My OS is Linux, self-compiled, based on LinuxFromScratch/BeyondLinuxFromScratch
Anyway, I now build audacity git master, with -Daudacity_use_sqlite=local, and everything is fine now, both old and new projects save and re-open fine.
