Missing metadata after export multiple
After I export files the artist and year seem to be missing from the metadata even when queried from the properties window under linux. I am running I believe 2.3.x of audacity under openSUSe Tumbleweed. I suspect the “artist” tag when exporting should probably be “album artist” (I believe I can manually add if required) and I have no idea what the proper tag for year should be. While here have another question. I have collection albums where each song has their own artist (none for the album). Should I enter (Various Artists) in artist or album artist? Should I enter the actual artist in an unavailable tag “contributing artist” (or maybe artist if the first answer is album artist) or something else. Again I can probably manually add these tags, if I knew which tags are correct.
Thanks for trying. You can close this.
