Missing Effect Items
Downloaded V2.3.3. In Effect Tab, at least the following are missing: Studio Fade out; Adjustable Fade; and in particular Filter Curve and Graphic EQ. See attachment. Any solution?
I think you will need to reset Audacity.
If you are on 64-bit Windows 10, shut down Audacity then open up:
Users\<username>\AppData\Roaming\audacity\
in the Windows file browser (File Explorer) and delete the three files:
audacity.cfg
pluginregistry.cfg
pluginsettings.cfg
Then restart Audacity. Those three files will be automatically recreated with default factory settings.
Thanks. That has solved the problem.
