Missing data (.au) Blockfile
Thanks for taking the time to help me out,
I’m Running Audacity 2.2.0
When I try to open my .aup file, I get the error:
Project check of “myfile_data” folder
detected 1 missing audio data (.au) blockfile(s),
probably due to a bug, system crash, or accidental
deletion. There is no way for Audacity to recover these missing files automatically.
yadayada… options to close, treat missing as silent, or permanently replace missing audio with silence (I was sure not to click this.)
The help log gives me this information:
14:10:01: Audacity 2.2.0
14:10:01: Trying to load FFmpeg libraries...
14:10:01: Trying to load FFmpeg libraries from system paths. File name is 'avformat-55.dll'.
14:10:01: Looking up PATH environment variable...
14:10:01: PATH = 'C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live;c:\Program Files (x86)\Intel\iCLS Client\;c:\Program Files\Intel\iCLS Client\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\Windows Live\Shared;C:\Program Files (x86)\QuickTime\QTSystem\;C:\WINDOWS\System32\OpenSSH\;C:\Users\TapMedia2.TapMedia-HP\AppData\Local\Microsoft\WindowsApps;'
14:10:01: Checking that '' is in PATH...
14:10:01: FFmpeg directory is in PATH.
14:10:01: Checking for monolithic avformat from 'avformat-55.dll'.
14:10:01: Error: Failed to load shared library 'avformat-55.dll' (error 126: the specified module could not be found.)
14:10:01: Loading avutil from ''.
14:10:01: Error: Failed to load shared library '.dll' (error 126: the specified module could not be found.)
14:10:01: Loading avcodec from ''.
14:10:01: Loading avformat from 'avformat-55.dll'.
14:10:01: Error: Failed to load FFmpeg libraries.
14:10:01: Error: Failed to find compatible FFmpeg libraries.
14:10:02: Error: can't open file '' (error 0: the operation completed successfully.)
14:10:03: Warning: Missing data block file: 'C:\Users\TapMedia2.TapMedia-HP\Desktop\Audacity\joey\myfile_data\.au'
14:10:03: Error: can't open file '' (error 0: the operation completed successfully.)
I had saved the file successfully, and then had opened some other .au files and did some post-production (including several saves). I also thought to rename the folder they were saved in from “new folder” to “audacity”. I tried changing the folder name back, but that didn’t solve the issue. In the same directory where the myfile.aup file is-- there is a directory called myfile_data, which has 323 files in it. If I select the option to treat the missing files as silent, I am left with zero audio within my project.
C:\Users\TapMedia2.TapMedia-HP\Desktop\Audacity\joey is where the “my file.aup” file lives
C:\Users\TapMedia2.TapMedia-HP\Desktop\Audacity\joey\my file\e00 is where a d00 and a d01 folder contain 323 files lives
Am I screwed with this file? It seems like the files are there… I don’t understand what the issue with the shared dll is in the above log. If I’m screwed and you’ve any idea what I did to mess it up, it would be good to avoid breaking my save files in the future. Thanks for the help!
Probably yes.
“FFmpeg” is an optional library that enables Audacity to support additional file types. It is not related to this problem.
Very hard to guess what caused the problem, but I would recommend updating Audacity to the current 2.4.2 version at your earliest convenience.
Audacity 2.4.2 is available via the Audacity website: Audacity ® | Download for Windows
If you also want to install the optional FFmpeg library, the instructions are here: Installing FFmpeg for Windows - Audacity Manual
