Hi,
I’m using Audacity to edit some voice over files that were recorded in Logic. When I export the audio using “Export Selection,” the resulting file seems to have a small amount of distortion. I initially thought it might be a compression issue since I was exporting to MP3, but I’ve tried exporting to WAV and got the same result. I don’t seem to get the distortion when I use “Export Multiple.”
Audacity 2.0.0
Windows XP
Any thoughts?
