Microphone
I am using a MXL 990 Condenser microphone and when I record it statics only when i speak when i listen to the recording. Is there any way I can fix that?
When you play the work, does the bouncing sound meter go all the way up and turn red, and do the blue waves fill the space top to bottom? It sounds like overload.
View > Show Clipping. Do you get a lot of red lines?
yep and how would i not over load it the meter?
