Microphone sounds very soft then loud at a threshold
So I used one of the tutorials online on how to reduce background noise.
It worked great except that now when I record if I talk very low then the sound is very low, but then once I reach a certain level the audio seems amplified and sounds much too loud after just being very soft.
All I really want to do is remove this and go back to how it originally was because I can’t figure out a way to fix this issue,
please help
What tutorial? Any of these effects can cause unwanted side-effects. But, I assume you’re not using Audacity’s Noise Reduction effect?
Did you turn-on [u]Windows “Enhancements”[/u]?
