The metafile editor carries over information from last edit session to a new session. It fills in any blanks in the current session with entries from previous session. For example, if the name of an album is blank, the editor writes in the album name of the last file edited.
Ensure that you “Close” each project before starting a new one, or use “File menu > New” to create a new project.
Sure, this is a workaround but it is tedious when processing lots of files. If I try to do batch processing with a macro, it creates chaos in my metafiles. It would be better if the buffer were cleared after each file is closed. If there is a workaround for this, please let me know.
