Metadata not working in 3.4
Hi, I’ve just downloaded 3.4. Metadata entered is not being saved to the file. I have returned to 3.3.3 until this is resolved.
I am unable to duplicate your issue. In Audacity 3.4.0 on Windows 10, I just Generated a chirp and did File>Export>Edit Metadata, then Export, and the “MyArtist” that I entered was propagated to both a .WAV and .MP3 file that I created.
Hi Jademan, I have tried it again, it is now embedding the metadata fine. Possibly the first download was faulty?
Hi, a further update. It now doesn’t always embed the data, but if I open the saved file the data is still in the Metadata editor. If I then export it again the data is correctly embedded.
Also see: v3.4.0 Meta data set default not working on audio export · Issue #5494 · audacity/audacity · GitHub
