If you have multiple files open in the same project (which you can get by using File → Import instead of File → Open) you can click the track name above the waveform and drag to the right. When you export (r when you play) everything will be mixed-down to stereo but you’ll be “mixing” a lot of silence.
That makes sense. Dragging the files to the right of the previous track allows them to play one after another and I can still modify each track individually.
Question - Let’s say I had 100 audio files that I wanted to play one after another, instead of over top of each other. Is there a way to add the tracks in one after another automatically without having to drag them to the right of the previous track above in my project.
Or… Can I just export them one after another in order from top down, rather than playing them over top of each other?
