Hi, for my guitar practice I use the repeat function. In versions 3x each repeat is now a section. How can I merge them into one section?.
thanks
John
I’m not sure exactly what you are asking. Try Ctrl+A to select everything, then Edit > Audio Clips > Join.
That did the trick. Thanks very much for your assistance.
John
