I just bought the cd ‘What Hits!?’ by Red Hot Chili Peppers at a Goodwill store. Unfortunately, two of the tracks are pretty badly damaged. However, I also have the Chili Peppers cd ‘Freaky Styley’ on which these two tracks originally appeared. And so I thought I could take the two tracks from ‘Freaky Styley’ and replace the bad ones on ‘What Hits!?’.
My issue is that the gain/volume levels on the ‘What Hits!?’ cd are higher than those on ‘Freaky Styley’. So my question is…
Is there a way in Audacity to use one track as a ‘template’ to automatically adjust the gain/output levels on another track?
I tried to manually adjust the levels and seemed to get pretty close, but now I’m wondering if there’s a way to automatically do it.
Then after you know the dB difference, you can enter a negative dB value into the Amplify effect to bring-down* the too-loud tracks.
In general, you have to reduce the loud tracks rather than boosting the quiet tracks because there is a “digital maximum” of 0dB, and since the peak levels don’t correlate well with perceived loudness, quiet-sounding songs are often normalized/maximized for 0dB peaks and their volume can’t be increased (linearly) without clipping (distortion).
