markers
L.S.
I have logged pieces of audio of mp3s I would like to cut out, but of course when i start with cutting out one piece at a particular time, the times change and the other times i have logged become useless. Is there any way I can " mark" several and cut them out all at once, so this problem is circumvented?
thank you in advance!
Niels
try working from the back to the front - then the earlier times will remain valid.
I do this when working on Audacity recordings of radio shows when I want to get rid of the chat between the music.
Sounds like a good option! thanks!
N
The other trick is to make sure both the label track and the audio track are selected before you hit delete (shift-click on the track panels to get there), so that both shrink by the same amount, keeping sync.
