Markers done, but won't go "with" audio track
I can make the markers on an audio track, but how do I export the audio track with the markers intact for the engineer? Please someone send me any easy solution oy. Thank you!
Unless something changed (someone will correct me) Audacity doesn’t have markers. It has labels and I don’t think you can export them with a sound file.
As Koz says but you can export the audio file and separately export the label file.
You can then send both to the engineer and he can import both files into the same project.
Peter.
Ding! I knew this was enough of a problem that some method was found.
