Manual .pdf
Is there a .pdf version of the manual? If so, where can I get a copy of it? I am using the latest version 2.0.5 under Windows 7 Home Premium. I would love to really get into this software.
Not unless you make your own PDF from the HTML Manual at Audacity Manual . We have never found a way to make the HTML image maps in the Manual translate correctly to PDF.
Thanks
What are your own reasons for preferring PDF?
I am having a hard time trying to figure out how to use the software via the online help. I have always had better luck using hard documentation.
That would be a lot of printing to do, even if there was a PDF.
Does it help if you enter your desired search inside the quotes here: "Device Toolbar" site:http://manual.audacityteam.org/o/ - Google Search ?
I will try that. Thanks
