First, thank you for making Audacity freely available.
Maybe you folks can give me helpful info on the following problem:
I recorded (German) words like “Katze” (cat) and “Chamäleon” (chameleon) with the Text-to-Speech service on acapela-box.com. The samples sound fine. (I used the voice “German - Julia”).
With Audacity 1.2.6, I cut the sample “Katze” into the individual sounds, i.e. “K”, “a”, “tz”, “e”, and saved them as individual WAV-files.
I wanted to make loops out of these individual sounds. I took a part from the middle of the “a” sample, put it in a new Audacity project and repeated it. But the result sounds very unnatural, like a very fast “Aa-Aa-Aa-Aa-Aa-Aa” (without gaps, though), not a continuous “aaaaaa”.
I tried to match the beginning and end of the selection which I looped. I put the beginning of a selection where the signal curve is at the bottom and starts to rise, and did the same for the end for the selection. Didn’t help, though.
(In the case of “tz”, I intended to make a looping “z” sound (omitting the “t”). But I had the same problem: the result sounded like a very fast “Zz-Zz-Zz-Zz-Zz”, not like “zzzzz”.)
Do you think it’s possible to take short word samples from that Text-to-Speech service and make decent loop sounds for the individual sounds of the word? If yes, could you give me any links to instructions for this on the net?
Or is it absolutely necessary to make much longer samples myself, i.e. saying “tzzzzzz” into a microphone and using the long “zzzzzz” to make a loop?
I really wanted to use that TTS synthesizer, though, as that’d enable me to make new sounds with their female voice anytime, instead of having to organize recording sessions every time.
Thanks in advance, Kibbi
