Make voiceover with music
Hello all,
I am hoping to get my hand held a bit so as to limit the number of wrong rabbit holes… :confused:
The scenerio:
I would like to record high quality MP3’s that can be downloaded from the web. The MP3 will have me talking and some light background music.
I will be using:
  • my computer (windows 7 PC)
  • Audacity
  • Heil PR40 and
  • something (maybe the Shure X2U XLR-to-USB Signal Adapter) to get Heil microphone working with computer because the Heil is pre-amp.
Will this work? Are there any suggestions or am I missing something???
I’m also not clear if it will be possible to record / export in stereo using the aforementioned equipment.
Looking forward to being schooled…thanks!
Top of the list: A very quiet and echo free room. Do you have that?
Next on the list: A pop filter (http://en.wikipedia.org/wiki/Pop_filter)
Next on the list: Lots of time and patience.
That mic deserves a better interface than the Shure X2U.
http://recordinghacks.com/microphones/Heil-Sound/PR-40
The mic is specced at -54 dB. That’s pretty low output. It’s a cardiod, so you need to watch out for keeping the narrator’s distance to the mic constant when recording. Unless you want proximity effect, of course.
Maybe a Focusrite 2i2?
http://global.focusrite.com/usb-audio-interfaces/scarlett-2i2
50 dB mic gain should be enough for voice recording, unless you have a noisy room. The gain is the same as the X2U, but the S/N ratio is a bit better.
ahhh…thanks for the input both of you.
I saw a video in which the person using the PR40 did have to stay mighty close to the mic and if he moved much, it could be really heard on the recording.
Interesting info…
I have an X2U and I would not buy another one. It suffers from low volume and higher than I would like noise (hiss) level. It does have high-end features. It will supply 48 volt phantom power, it does not suffer from the dreaded USB whine sound and it supports a headphone connection.
The ACX people have produced a video with their recommendations and they have a microphone and MicPre that they like. I have no personal experience with either one.
I think it’s in the first video.
http://www.acx.com/help/video-lessons-resources/200672590
USB direct MicPres tend to all suffer from low gain. As I posted, overload and sound clipping is immediately fatal to the show and could result in a returned product. Low volume is always assumed to be fixable with enough time and effort and so the product stays bought. Much better (for them) to have low volume.
That’s not how I do it. For very nearly the same money, I have a “real” but small, full sound mixer.
http://www.sweetwater.com/store/detail/PV6
That has no such problems as low volume, lack of control or high noise level. This is it doing a broadcast radio sound shoot.
The down side is the operator has to have some idea of what they’re doing. It’s not plug and play, although sound mixers tend to look more complex than they are. You can generally turn off or neutralize the services you don’t understand and they work just fine.
I’m plugging my mixer directly into a Mac which was specifically bought because it has a very high quality stereo line-in connection. If your machine doesn’t have that, then you need to add a high quality USB digitizer such as a Behringer UCA202 that I use. This is one with my mixer and a Windows laptop.
This system has also been certified for musical overdubbing should you need to do that.
I thought I posted this. These are the three mixer knobs that control the show. All the rest of the knobs can be left off or neutral.
Thanks Koz for the detailed info! Pictures speak a thousand words. This is great food for thought. The available rabbit holes are becoming fewer and fewer. :smiley:
This is an X2U test with my normal voice and microphone. The noise after I stop speaking has no whine or whistles in it, but the shshshshshsh sound is much too high. That’s not my room or microphone. The X2U is making that.
The instruments say -49dB in that clip. ACX AudioBook standards are between -96dB and -60dB (much quieter).
