Make audio hearable
i have recorded some audio in theathre
now need to make it more hearable
https://www.sendspace.com/file/mavvag
That’s hopeless.
Next time you record one of these, you should turn off the automatic voice processing, noise reduction and echo suppression. In short, casual recordings that can help, but in longer, lower volume recordings it will just kill you. It screws up rescues.
And take the recorder out of your pocket.
