Make Audacity record automatically at a certain time [SOLVED
I know how to make the program run at the certain time but how do I program it to start recording audio from the PC? (I dont want to have the PC speakers on at the time!)
Thanks
Audacity has a fairly basic but functional “timer record” feature: http://manual.audacityteam.org/o/man/timer_record.html
Then turn off Software Playthrough in the Transport Menu - See this page in the Manual: Audacity Manual
Though I deal with this by plugging in my external active speakers and turning the volume control on them right down :wink:
You need to have the audio running and you need to make sure that your Device Toolbar settings are correct for recording from the computer (make a small test recording) - then set Timer Record.
One of the best forums. Thanks for the detailed and promp responses guys. This solved my problem
