Hi,
I have a Macro that I apply to most new files that I start working on - a Normalize, a Filter Curve with a Low-Rolloff, and then a Regular Interval Labels.
Each effect in the Macro uses a Preset that is assigned to the Macro. The Presets work fine in the Normalize and Filter Curve, but the Regular Interval Label part of the Macro just uses the last set of options that was used when Regular Interval Label was used independently of the Macro instead of applying the Preset that the Macro calls for.
When I use Regular Interval Labels outside the Macro, the Preset works fine. Below is a screenshot of the Macro commands:
I think this issue cropped up with 2.4.1. Any ideas about what’s happening.
Thanks,
Mike
