It would be helpful to have two additions to the MACRO feature:
“Duplicate” - the selected macro would be duplicated and name appended with “- copy” - the focus moved to the new duplicated macro button.
Show all macros when “Apply Macro” is selected - The problem is that when there are multiple projects open and a new macro is created, only macros which were created prior to the opening of any project appear in the available Macro list.
A workaround I have found is to create another “New” macro with the same name. The previously created macro appears, can be "OK"ed and used.
