Macro export
Hey,
I’d like to use my macros on another computer.
Is there a way to export them or something?
Thanks
Daniele
Your macros are in the folder at “~/Library/Application Support/audacity/Macros”.
– Bill
Thanks, billw58, unfortunately, I can’t see any Macro folder in there…just a ‘lib’ folder.
I’m running Audacity 2.3.1 on MacOs Mojave 10.14.4
Can someone please advice?
I finally got the problem. I had to check the “show Library Folder” in my view option…now I can see the Macro folder (and other stuff I was looking for).
Thanks!
That’s because you missed the little squiggly character “~” (called tilde) off the front before /Library…
That’s two different file locations - Mac likes to make things complicated with very similar pathing names
